So this started a week ago , all was working well and when I turned off my PC , it said
"USB DEVICE OVER CURRENT STATUS DETECTED. Shutting down in 15 seconds".
I tried these and still not working :
- Unplugged everything from the back usb ports except for the keyboard and mouse,then when i turned on , still not working soI unplugged both also.Still did not work
- Removed the front usb ports from the motherboard.
- Removed the CMOS battery for 5-10 seconds and also the jumper to enter BIOS,still can't enter bios to reset
My motherboard is ASUS . It will be very helpful if you respond
