G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics (More info?)
I have a USB 256MB flash drive. It works fine in an old Win98SE
system. It works fine in the backplane connectors on my new ASUS
P4P800E Deluxe WinXP system (Win XP Pro SP2). But if I insert it in
either of the front connectors in the case I get the following error
balloon:
USB device not recognized. One of the USB devices attached to this
computer has malfunctioned, and Windows does not recognize it.
Clicking on the balloon calls up a table with the correct port
identified, and the above message repeated along with the advice:
Try reconnecting the device. If Windows still does not recognize it,
replace the device.
Now, I'm not about to replace the device - it works fine. And if
there is a fault in the port it's a very subtle one, because my
digital camera is recognized on the same port & I can download images
with no problems. Any suggestions? It's a pest to pull the computer
out to access the back ports whenever I want to use the USB drive.
Dave Gillingham
To email me remove the .private from my email address.
G
Guest
Guest
The front ports may not be correctly set up. This is a common problem. In
some cases, the connectors are not attached and in others the jumpers are
not correctly set.
Colin Barnhorst [MVP Windows - Virtual Machine]
(Reply to the group only unless otherwise requested)
"Dave Gillingham" <dewg@private.optusnet.com.au> wrote in message
news:vp0u115me1flkdpi2klhf91ivih9tebi3h@4ax.com...
> balloon:
> replace the device.
> Dave Gillingham
G
Guest
Guest
But I can download fine from my digital camera, using the same front
usb port! That's why I'm so frustrated.
On Fri, 25 Feb 2005 09:16:44 -0700, "Colin Barnhorst"
>not correctly set.
Dave Gillingham
G
Guest
Guest
Dave,
It might be that the front USB ports do not provide enough power to run your
flash drive. The reason that your digital camera works, because it is
providing the additional power needed, either with the internal batteries,
or external power adapter. Some PC's front USB ports will not support USB
printers, scanners, external hard drives, and must be connected to the rear
USB ports.
Add MS to your News Reader: news://msnews.microsoft.com
Rich/rerat
(RRR News) <message rule>
<<Previous Text Snipped to Save Bandwidth When Appropriate>>
news:dhk0215vtnt1bptdd2d6uucr4q292ia9a7@4ax.com...
>not correctly set.
Dave Gillingham
G
Guest
Guest
As I said check the connections. Perhaps power was never connected.
"RRR_News" <rrr_news@isp.com> wrote in message
news:O8JpfAAHFHA.3912@TK2MSFTNGP10.phx.gbl...
> Dave,
> your
> rear
> USB ports.
> Rich/rerat
>>In
>>not correctly set.
> Dave Gillingham
