USB Devices randomly dropping
LegitBoss002
35
Throughout the day my microphone (Blue Yeti) Mouse (Logitech G502) and mousepad (MM800) have been disconnecting for a second or two, then reconnecting. It's always the same devices and they are fine most of the time. It seems to happen once every 2 hours or so.
Edit: The mouse disconnects regardless of where it is plugged in. Directly to the motherboard, USB pass-through on the mouse-pad, and the USB pass-through on the keyboard.
Motherboard: Asrock x370 Killer sli/ac wifi
OS: Windows 10 home
Figured out the issue. I have a vega 64 and an overclocked ryzen 5 1600 running on a 500 watt psu. I went back to stock clocks on the ryzen chip and am not having issues anymore. I assume the problem was either the overclock causing issues, or the power draw because of the overclock leading to the psu not being able to keep up
