Hi, my USB ports on my motherboard are disconnecting and connecting. I have Asus TUF B450 PRO Gaming. What should I do?
Windows 10 Pro 64-bitFirst make sure that your motherboard is on the latest BIOS update. Next you should install the chipset drivers for the motherbaord manually, in an elevated command, i.e Right click installer>Run as Administrator.
Which version of Windows 10 are you on?
