USB drive Write Protected
sumaira1
hi i cant fixed my problem, after doing all of this, i cant format my flash drive please provide me any other solution ?
Hope this will help you...
for windows only
Click start
then run regedit
go to this directory HKEY_LOCAL_MACHINE\SYSTEM\Currentcontrolset\control\
if you can't find StorageDevicePolicies under control folder
then make some new one. Follow this steps:
step 1:
again and right click control folder
step 2:
select new, then click key and rename the new key #1 folder into
step 3:
right click StorageDevicePolicies folder and select new DWORD(32-bit) Value
for 32-bit Operating System and select new DWORD(64-bit) Value
for 64-bit Operating System
step 4:
rename dword newer folder into WriteProtect, then double click WriteProtect...
for windows only
Click start
then run regedit
step 1:
step 2:
step 3:
step 4:
and change the value data into 0 with hexadecimal base, Then close regedit
step 5:
open my computer and refresh it 5 times without do anything to your usb, and
properly eject your flash drive
