[SOLVED] USB driver for Fiio usb sound interface
Theresa N
Admirable
Dec 10, 2019
88
18
7,165
I use a Fiio usb dac/headphone amplifier with Windows 10. Would like to use Linux in a dual boot configuration with it. I would probably work in low bit rate and depth without a driver but I like to listen at higher bit rates and depth. Anybody know of a solution? I have searched the web with Duck Duck Go and didn't find anything applicable.
The linux kernel contains all current drivers. If your specific hardware isn't supported by one of those then it means that no one has seen the need (as yet) to write a driver, and for the present you are out of luck. Unless of course you are skilled in C/C++ and can write your own.
