Hello;
I have a generic USB DVD RW drive which works fairly well - a bit slow for ripping audio cd's.
But the most annoying aspect of this drive is that when you place a CD or DVD onto the pop-out tray, you must press the center of the disc onto the spindle so that it engages. I find this a serious setback when processing many cd's, or just playing a DVD movie.
What I am looking for is a portable USB drive that has the same sort of tray that a standard bay (like those mounted on a PC's front panel) drive would use.
The problem is that my box doesn't have any optical drive bays up front. I could add a SATA extension cable on a rear plate (I already have the plate with 2x SATA port) but then I would need to use an extra long (3ft) SATA cable to reach the drive from the rear of the box.
What I am finding at Amazon and Newegg are the 'slim' drives intended for laptops, and they all use the same method of latching the disc to the spindle - manually.
Does what I am looking for exist?
Thanks
Ultrarunner
Thanks
Ultrarunner
