USB Ethernet Adapter no Longer Works With Gigabit Speeds
fb39ca4
968
I have an [Anker USB hub+gigabit ethernet adapter](https://www.anker.com/products/68ANHUB-U3E1A) (the Ethernet chip is made by Realtek) I have been using with my computer for over a year now. About two weeks ago, I moved to a new place with gigabit internet, and plugged my computer directly into the jack through this adapter to confirm, and I was getting speeds of 900+ megabits. However, my router only had 100 megabit ethernet so I was using it at those speeds.
Today, I got a new router (Linksys E4200 running AdvancedTomato) with gigabit ethernet, but when I plugged the adapter in, it only connected at 100 megabit speeds. I tried different cables and nothing changed. I also tried connecting directly to the wall again, but it only connected at 100 megabits rather than 1 gigabit two weeks ago. I have also tried reinstalling the drivers in Windows, and using Linux, but neither of those helped.
Here is the output from ethtool on Linux:
Code:
Settings for enp0s20f0u2u3:
        Supported ports: [ TP MII ]
        Supported link modes:   10baseT/Half 10baseT/Full
                                100baseT/Half 100baseT/Full
                                1000baseT/Half 1000baseT/Full
        Supported pause frame use: No
        Supports auto-negotiation: Yes
        Advertised link modes:  10baseT/Half 10baseT/Full
        Advertised pause frame use: Symmetric Receive-only
        Advertised auto-negotiation: Yes
        Link partner advertised link modes:  10baseT/Half 10baseT/Full
        Link partner advertised pause frame use: Symmetric Receive-only
        Link partner advertised auto-negotiation: Yes
        Speed: 100Mb/s
        Duplex: Full
        Port: MII
        PHYAD: 32
        Transceiver: internal
        Auto-negotiation: on
        Supports Wake-on: pumbg
        Wake-on: d
        Current message level: 0x00007fff (32767)
                            drv probe link timer ifdown ifup rx_err tx_err tx_queued intr tx_done rx_status pktdata hw wol
        Link detected: yes
As you can see, the adapter claims to support gigabit, and the router it is connected to advertises it, but the adapter is not advertising gigabit. I have also tried forcing gigabit using `ethtool -s enp0s20f0u2u3 speed 1000 duplex full` but that did not work and the adapter reconnected at 100 megabits some time later.
Yes, I downloaded the newest drivers for it from Realtek's website. The router doesn't seem to have any problems, and like I said in the first post, the USB adapter directly plugged into the wall no longer gets gigabit speeds, whereas two weeks ago it used to.
