Usb external hard drive disk with extension cable
jerry22
Hi guys, how is it going?
I hope you have time to take a look at my problem, please
I own an usb external hard drive disk, which supports usb 3.0, from toshiba. The original cable is very short so I bought an usb extension cable. I connected it to the external hdd but it doesnt work, i can only hear a sound similar to "tik tik" or "click click" coming from the hdd and nothing shows on my computer. I tried the cable with an usb pen drive (usb 2.0) and it works, so i dont think the problem is the extension cable. both hdd and the extension cable support usb 3.0 .
do you know how I can solve this problem?
Thanks
Regards
Jerry
Have you tried the USB drive directly with the computer, without the extension cable? If that works, my best guess would be that the inferior cable can't carry enough power for the hard drive, which draws more than the pen drive. Is it a USB 3.0 cable? If it's only 2.0, not only will you get slower data, but less power capacity.
