Hello,
I have read a lot of your threads on code 43 but they dont fit this one.
system:games, new,worked fine for 4 months, now crashes, win 10/64,MB-sabertooth X99 LGA2011 v3,cpu i7 5820 3.3GHZ, zotac geforce gtx 980 ti 6GB, SSD M2 samsung 950 pro 256 GB, corsair 4x4 GB DDR4 3000MHZ, mouse razer deathadder chroma m#RZ01-0121, keyboard corsair k95 RGB (two USB's), headset hyperx cloud2 USB, logitech thx speakers, PS rosewill capstone 1200W, blue ray LG disk, 2GB hd, & asus mg278 monitor.
system is clean not even office, just what is writen + norton. only one game ark and team speak.
MB BIOS was update after built.
Device manager
Universal Serial Bus controllers
I found a problem-
Unknown USB Device (Device Descriptor Request Failed)
(Properties-General) Windows has stopped this device because it has reported problems. (Code 43) A request for the USB device descriptor failed.
(Details- property) Device instance path- value-USB\VID_0000&PID_0002\5&1CC0E58A&0&14.
(Details- property) Problem code-value-0000002B.
(Details- property) Address- value-0000000E.
(Details- property) Base container Id-Value-{1708a73f-fd2f-11e5-bdc7-f832e4701ca6}.
(Details- property) bus type Guid- Value-{9d7debbc-c85d-11d1-9eb4-006008c3a19a}.
(Details- property) Location infomation- Value-Port_#0014.Hub_#0003.
(Details- property) location paths-Value- ACPI(_SB_)#ACPI(PCI0)#ACPI(XHCI)#ACPI(RHUB)#ACPI(HS14).
(Details- property) Manufacturer-Value- (Standard USB Host Controller)
This problem never goes away. Head set, mouse, KB, speakers work.nothing else is or has been plugged in.un plugged head set still there.
Note: i just reinstalled fresh win 10, drivers updates to see if it was a software problem, still there.
Here is the newb question.
How do I find, what USB, is the Problem?
Thank you
Device manager
I found a problem-
Thank you
