USB faster on USB 2 or 3 or The Same?
DASMANgaming
62
I have a oldish USB and I want to move some files to it but I am curious to know if it would transfer faster if it was plugged into a USB 3 or USB 2 port. It would help me a ton if I could know what one would be faster or if their wont be a difference.
I've plugged in my USB 2.0 stick in a USB 2 drive and 3 Drive. I can see a little difference and it seems like that the speed of transfer remains the same. However the stick in USB 3 hub acts faster. But anyone can give you their own opinion. Just test it out on few files and find out for yourself.
The usb 3 port will be faster then the 2 port but it will depend on the device you are using. Since you said its older then im guessing its ether usb 1 or 2 which then you will be limited by the devices speed not the plug on your computer.
Latest posts
