USB Flash drive for a router.
soumensam
16
Hi there,
I’m looking to setup a USB Flash Drive with a router. I want to use its as a Network Drive with larger storage/memory for a small office. But before doing I’ve several questions.
# The Router is TP-Link Archer C20i and it has one USB 2.0 port so If I get a USB 3.0 Flash Drive would it be any beneficial? I mean speed like 3.0 or better speed than 2.0 or I will get same speed of 2.0.
# Can I mount a External hard drive like 500GB or these routers has any limited memory support range? I’ve one but didn’t not test it yet as it’s NTFS File format and not sure if the router only works with FAT32.
# With a Sandisk USB 2.0 over wifi writing speed is pathetic maybe like 2-3mbps but over LAN the speed is around 8mbps. Going for a 3.0 would increase the writing speed over wifi?
# I was looking for smaller size Flash drive to save space but all the 3.0 tiny size are reporting they are not for permanent installation as these becomes hot shortly. Could the heat make any damage to the router? Currently I’m testing with a Sandisk Cruzer Blade and so far after few days of constant attachment it didn’t get heat at all maybe due to the plastic body. So is it better to going for the same one with larger capacity as much as possible?
Because I’ve used and seen others that a USB 3.0 flash drive gives better speed than a USB2 flash in USB2.0 port of a PC. Not same as USB 3 to 3 but better than usb 2.0 drives. But don’t know if this does same for the router.
