USB Flash Drive Formatted to wrong storage size
ItsPepi
15
From the elevated cmd prompt (run as administrator) run these commands
diskpart.
list disk.
select disk {number}
clean.
create partition primary.
select partition 1.
active.
Then format
when it was used as a recovery drive the partition on there protected from gui format, need to remove that partition
diskpart.
list disk.
clean.
select partition 1.
active.
Then format
