Question USB Flash Drive not working
Sep 21, 2021
Hello. Could you please help me fix a flash drive? It was installed in a tv box, as an internal device. After removed it I can not use it anymore. I tried fixing it on Windows 10 and Ubuntu with no success. This is the log of the drive. Thanks.
Sep 22 00:05:27 bobski-ThinkPad-X230 kernel: [ 657.065256] usb 3-1: new high-speed USB device number 7 using xhci_hcd
Sep 22 00:05:27 bobski-ThinkPad-X230 kernel: [ 657.213547] usb 3-1: New USB device found, idVendor=ffff, idProduct=1201, bcdDevice= 0.00
Sep 22 00:05:27 bobski-ThinkPad-X230 kernel: [ 657.213560] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Sep 22 00:05:27 bobski-ThinkPad-X230 kernel: [ 657.215126] usb-storage 3-1:1.0: USB Mass Storage device detected
Sep 22 00:05:27 bobski-ThinkPad-X230 kernel: [ 657.215768] scsi host6: usb-storage 3-1:1.0
Sep 22 00:05:27 bobski-ThinkPad-X230 mtp-probe: checking bus 3, device 7: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1"
Sep 22 00:05:27 bobski-ThinkPad-X230 mtp-probe: bus: 3, device: 7 was not an MTP device
Sep 22 00:05:28 bobski-ThinkPad-X230 kernel: [ 658.225551] scsi 6:0:0:0: Direct-Access NAND USB2DISK 0.00 PQ: 0 ANSI: 4
Sep 22 00:05:28 bobski-ThinkPad-X230 kernel: [ 658.226046] sd 6:0:0:0: Attached scsi generic sg1 type 0
Sep 22 00:05:28 bobski-ThinkPad-X230 kernel: [ 658.265948] sd 6:0:0:0: [sdb] Attached SCSI removable disk
Sep 22 00:05:39 bobski-ThinkPad-X230 kernel: [ 669.581133] usb 3-1: USB disconnect, device number 7
Sep 22 00:05:53 bobski-ThinkPad-X230 kernel: [ 683.393310] usb 3-1: new high-speed USB device number 8 using xhci_hcd
Sep 22 00:05:53 bobski-ThinkPad-X230 kernel: [ 683.541647] usb 3-1: New USB device found, idVendor=ffff, idProduct=1201, bcdDevice= 0.00
Sep 22 00:05:53 bobski-ThinkPad-X230 kernel: [ 683.541660] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Sep 22 00:05:53 bobski-ThinkPad-X230 kernel: [ 683.543287] usb-storage 3-1:1.0: USB Mass Storage device detected
Sep 22 00:05:53 bobski-ThinkPad-X230 kernel: [ 683.543929] scsi host6: usb-storage 3-1:1.0
Sep 22 00:05:53 bobski-ThinkPad-X230 mtp-probe: checking bus 3, device 8: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1"
Sep 22 00:05:53 bobski-ThinkPad-X230 mtp-probe: bus: 3, device: 8 was not an MTP device
Sep 22 00:05:54 bobski-ThinkPad-X230 mtp-probe: checking bus 3, device 8: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1"
Sep 22 00:05:54 bobski-ThinkPad-X230 mtp-probe: bus: 3, device: 8 was not an MTP device
Sep 22 00:05:54 bobski-ThinkPad-X230 kernel: [ 684.561698] scsi 6:0:0:0: Direct-Access NAND USB2DISK 0.00 PQ: 0 ANSI: 4
Sep 22 00:05:54 bobski-ThinkPad-X230 kernel: [ 684.562053] sd 6:0:0:0: Attached scsi generic sg1 type 0
Sep 22 00:05:54 bobski-ThinkPad-X230 kernel: [ 684.605876] sd 6:0:0:0: [sdb] Attached SCSI removable disk
Sep 22 00:06:18 bobski-ThinkPad-X230 kernel: [ 708.707254] usb 3-1: USB disconnect, device number 8
