[SOLVED] usb flash drive problem
Oct 16, 2019
I think i ruined my flash drive ,i connected it to a badly wired front usb port and it just wouldnt work after that ,i just cant understand what could have happened and is there any chance that i could send it for a warranty replacement ?
How do you know the USB port was badly wired?
Although.....if it was....I am not surprised the USB is damaged.
You can try and RMA it and hope for the best....but if the damage was caused by a miswired USB port....it's your fault.
Oct 16, 2019
thx for the reply ,i shall send it and try my luck.
