USB Flash Drive Problem
D3ZiR3aL
Hey Guys.
I have recently had a problem with my flash drive and it is unexplainable, it has me stumped.
My flash drive specs: Sahara edrive 512MB
Well This is the story
I was at work and my friend who i work with said that he could put a pass on my flash drive with his edrive flash driver disk and so he tried and now the flash drive is buggered.
When i put it into a machine it will install but as SiS150a device
but it neva used to do that it would just say installing Hi-Speed USB drive and then i could use it. But now windows doesnt read it as a flash drive and it says that the file system is unknown and well it is not readable.
Please any advice would be great appreciated
Thanks in advanced
Peace
D3ZiR3aL
g-paw
Splendid
Jan 31, 2006
4,479
The first I'd do is see if you friend can uninstall whatever he installed. If not, see if you can format it. I don't know if you format flash drives, never tried, but check the support site of you flash mfg
D3ZiR3aL
I have tried to format it windows says there is no disk inserted and the program my friend used doesnt detect the flash drive.
Similar threads
