G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Hello.
I've been using a USB 1.1 Flash Drive (64mb) with various windows xp
computers since January and have not had any problems.
However today, when I inserted the drive into a USB socket on the main
computer I've been using it with I received a popup saying 'new hardware
detected'. Windows then started installing drivers for it.
When I looked for it in My Computer/Windows Explorer I found THREE new
drives instead of one and none of them work. When I try and open each one it
says 'insert a disc'. I cant format them as the computer thinks that no disk
is inserted.
The USB Mass Storage device appears in the Device Manager with no problems.
The Flash Drive has been working fine on this computer. I've not installed
anything new since I last used it. It shouldn't have recognized it as new
hardware because it has been installed for nearly a year and is not new.
I tried it on another USB port with the same results. I then tried it on
another computer (which it has worked on fine in the past), also running XP,
and the same thing happened. It said it was new hardware and began
installing drivers, when it finished I had 3 new drives again and each one
is empty and useless i.e. when I try and open them it tells me to insert a
disk into the drive (how can you insert a disk into a flash pen
drive???**!!)
I have files on the drive I don't want to loose. I've not found anything
similar on the web or newsgroups.
Can anyone here suggest what might be wrong?
Thanks.
Hello.
is inserted.
drive???**!!)
Thanks.
