USB flash drives causing drop in wifi?
TommyGar
38
Hey, so it seems like every time I insert a USB flash stick into my PC the USB WiFi adapter takes a dump.
Is there something wrong with my USB connectors? Or is this to be expected? Any ideas?
Windows 7 64bit
Mobo: ECS A960M-MV
(http://www.newegg.com/Product/Product.aspx?Item=N82E16813135349&cm_re=ECS_A960M-MV-_-13-135-349-_-Product)
Wifi Adapter: TP-Link TL-WN722N
(http://www.newegg.com/Product/Product.aspx?Item=N82E16833704045&cm_re=tl-wn722n-_-33-704-045-_-Product)
This is definitely not expected or usual. I am guessing there is an issue with the USB ports.. I would try to look for an updated USB driver, and try running the wifi adapter in a different usb port.
