USB Hub conflict
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Hub is a DLink and there are no drivers available at their site. Win2K hangs on shut down. What shall I do next to solve this? I tried a new Belkin hub with same results.
d
Go to the scanners section for some more info on usb problems. I was just over there as I am having probs. with a usb scanner. I have a Belkin hub that works with everything but the scanner so Im pretty sure it isnt the hub. The hub requires no drivers other than the normal windows usb drivers. It may be that the device you are connecting needs power from the hub so be sure to plug it in.
You Dont Want To Be The Last to Know Anything.
