Question USB-HUB disconnection problem
May 23, 2019
5
Hi ,
The USB-HUB is self-powered, and two LTE modules are connected via USB-SERIAL to USB-HUB.
We are facing a problem is that,The devices which are connected to USB-HUB can not be accessed. Is there any investigation method and solution for this? please help me out
Below following are kernel Logs.
Kerenl log:
19:47:58 raspberrypi kernel: [ 9301.001438] usb usb1-port1: disabled by hub (EMI?), re-enabling...
19:47:58 raspberrypi kernel: [ 9301.001457] usb 1-1: USB disconnect, device number 11
19:47:58 raspberrypi kernel: [ 9301.001463] usb 1-1.1: USB disconnect, device number 12
19:47:58 raspberrypi kernel: [ 9301.001668] ftdi_sio ttyUSB2: error from flowcontrol urb
19:47:58 raspberrypi kernel: [ 9301.001872] ftdi_sio ttyUSB2: FTDI USB Serial Device converter now disconnected from ttyUSB2
19:47:58 raspberrypi kernel: [ 9301.001906] ftdi_sio 1-1.1:1.0: device disconnected
19:47:58 raspberrypi kernel: [ 9301.002107] ftdi_sio ttyUSB3: error from flowcontrol urb
19:47:58 raspberrypi kernel: [ 9301.003371] ftdi_sio ttyUSB3: FTDI USB Serial Device converter now disconnected from ttyUSB3
19:47:58 raspberrypi kernel: [ 9301.003429] ftdi_sio 1-1.1:1.1: device disconnected
19:47:58 raspberrypi kernel: [ 9301.010150] ftdi_sio ttyUSB4: FTDI USB Serial Device converter now disconnected from ttyUSB4
19:47:58 raspberrypi kernel: [ 9301.010212] ftdi_sio 1-1.1:1.2: device disconnected
19:47:58 raspberrypi kernel: [ 9301.010430] ftdi_sio ttyUSB5: error from flowcontrol urb
19:47:58 raspberrypi kernel: [ 9301.018012] ftdi_sio ttyUSB5: FTDI USB Serial Device converter now disconnected from ttyUSB5
I will appreciate your help and time
May 23, 2019
5
Thank you so much for your reply .
Today we tried with single port but we faced the same problem like below.
So the error "Disabled by hub (EMI?)" is the impact of Noise or Static electricity?
Can you please tell me. I am awaiting for your answer.
May 23, 2019
5
Thank you so much for your valuable information and your time.
The total current consumption of our LTE module is estimated as 2A.
The USB-HUB is 5V and it has a 3.5A Capability. In addition, CM3 also makes the power supply with this 5V.
So Do we need to separate the USB hub and CM3's power supply?
our steps are like below
  1. We are evaluating using CM3.
  2. USB hub and USB-UART are boarded on the IO board.
  3. USB hub is working in Self-power mode.
  4. VBUS-detect of USB-hub uses the same 3.3V power supply as CM3.
  5. Set correctly when in Power-On.
and this error occur only sometimes not always.
5
This is the block diagram. I hope you ll get more clear picture about the problem.
