https://onedrive.live.com/redir?resid=FC9E8FBC07BDACB!57504&authkey=!AOxGxqwv9gnym50&v=3&ithint=photo%2cjpg (mark this hole line)
In the link above you see how I tried to merge two USB Dupont Jumpers into one Dupont Jumpers, because I didn't have room for two.
The problem is, that then I connect it to the PC and connect a USB Drive it just says "unregonized USB drive". The thing is, that I have another USB Hub, which I bought in which the drive works fine.
Does anyone know why my DIY solution doesn't work, and explain the difference to a bought USB Hub
