USB Hub Power Exceeded
Kurewe
I understand that this topic has been covered numerous times. However, after reading the other posts, I wanted to see if there are any fresh ideas or fixes. Thanks for taking the time to read my post.
Recently I've started having this USB power issue pop up on random computers. So far, it's happening on two HP Ultra Slim Desktops and two HP Probooks. All of them are using Win XP and every one of them is a different model. The I haven't yet been able to find a fix. I first noticed the problem when trying to setup an XP PC with a 3rd display, using an iOGear USB to VGA adapter. I then noticed that not only would it not initialize the adapter due to the "USB Hub Power Exceeded", it would not initialize a USB flash driver either. Peripherals such as mice and keyboards do not seem to be a problem. The problem then popped up on a computer that was working without issue with a 3rd display attached via an iOGear USB VGA Adapter. Suddenly, it's having the same exact issues as the previous. When asking the other tech around the office, one had a notebook that has been doing this for 2 months and another just started having the problem last week on a notebook. Neither of these notebooks were/are using a USB VGA Adapter.
The notebook that came down with the issue last week seemed to do so right after some windows updates were installed. These are the updates, that I was able to find, which were installed just prior to the issue starting: KB2898785, KB2893984, KB2893294, KB2898715, KB2892075, KB2850085, KB2917500. I did not see any driver update installation and there was no other software installed just prior. I uninstalled each of these, one by one, and the issue remains.
I can tell you that all the normal suggestions have been tried and that "you have too many things connected by USB" and "Hide the USB Hub Power Exceeded notification" are neither the issue nor the solution. I swapped the hard drive into a PC that I had tested to be working properly and the issue followed. That ruled out any hardware issues as far as I am concerned. I checked several chipset driver versions and the problem didn't change. I checked the BIOS for a setting to reconfigure the USB 3.0 ports to function as USB 2.0 ports. However, HP has a limited function BIOS on these machines, so I was not able to adjust the USB 3.0 function to allow Windows to use the native EHCI driver. I've turned off any power management of the USB Root Hub(s). I've "uninstalled" the USB controllers and hubs through device manager and then let the system re-install after a restart. I've checked the drivers that are being used for USB against other computers of the same models that are working properly and there doesn't appear to be a difference in the driver. So, I don't think that the drivers themselves have been updated or changed. I am stumped.
Does anyone have any suggestions or hunches? Please don't re-hash the usual suggestions from all the previous posts. As I said, I have tried all the typical suggestions. Thank you in advance for taking the time to read my post and any useful suggestions you may have.
Kurewe. We are having this problem as well. I have started making some progress. I think if we both put our heads together we can solve this. Email me at travis@cityandruralrides.com Id like to brainstorm with you.
Travis
Information Technology Specialist
Central Texas Rural Transit District.
As I had run out of ideas and the problem seems to be popping up more and more, I decided to put together a system and duplicate one of the machines that recently came down with the issue. I started going step by step with the software installations until I dug deeper into the machine to determine everything that had been installed from October 2013 to present. When I got to the Windows INF folder, I found that several of the drivers installed were from Citrix. These drivers are USB Video Redirectors. When I found this, I recalled seeing the Citrix Connector software running on some of the other problem machines as well. I uninstalled the Citrix software, made sure the drivers were actually removed and then restarted the computer. When I logged back into Windows, I plugged in my flash drive, which wouldn't work just prior, and it actually worked this time. I didn't have time to do any more testing Friday. So, I when I returned to work this morning, I reconnected the third monitor via the IOGear USB adapter and waited to see what happened. Sure enough, the display came up and worked just fine.
I then started looking for an older version of the Citrix ICA Client/Receiver and ran across a single article on the Citrix support site that made reference to this exact issue.
http://discussions.citrix.com/topic/338636-a-usb-device-has-exceeded-the-power-limits-of-its-hub-port/
The suggestion was to contact Citrix Technical Support and quote LA4582. (I assume that LA4582 is an internal knowledge base article). I do not know what the solution is. However, I would imagine that it's to uninstall the current version (14.x) and install an earlier ICA Client/Receiver like version 12.x or 13.x. Or, to swap the ctxusbm.sys driver with an older version. I get the impression that the driver somehow adjusts/modifies the USB Hub Amperage readings from 500 mA to 100 mA and the XP OS then views that as an exceedance of the Hub's power.
I know that this has resolved my issue. I can't say if it will resolve anyone else's. Definitely check into what drivers/software have been installed. I never would have thought that the Citrix ICA Client/Receiver would have caused an issue with USB function. And definitely look past advice such as "plug in powered hub" or "you have too many USB devices connected" or "just upgrade to Win 7" or "use a USB Y cable" or "you have a hardware issue". Take some time and be methodical about your troubleshooting. You'll find the answer eventually.
By all means, if you have a question for me, feel free to ask. I'd be more than happy to help.
Hi, I want to thank you for helping me with the same issue. I would have never figured this out if it wasn't for your posting. I was at my father's house on his Windows XP machine and I installed the Citrix software so that I could do some work. Some time later we discovered the USB problem described in these postings. We spent a lot of time trying different fixes, hardware and software and nothing worked until your post. I am very thankful. -David
I found that un-installing all Citrix software and rebooting cleared this error.
Windows XP with a recently installed CitrixReceiver had the USB hub power exceeded problem. This thread was extremely helpful. Thanks a lot! By the way, about the same time fonts inside several programs started to look bad. Don't know if Citrix caused that too.
