Hello, I need a little education on how powered USB hubs work, I've searched around but can't seem to find an answer to my specific question.
I purchased THIS powered USB 3.0 Hub over a year ago, it looked like a nice solid unit with plenty of power to run the things I wanted to connect to my small laptop (external DVD burner, smartphone, mouse, keyboard). I am pretty happy with it, it does great with all of my peripherals, including charging my smartphone or whatever else I want to charge.... as long as the laptop is connected and powered on.
Here's my question: When my laptop is either turned off, or disconnected from the hub, the hub seems to only put out a trickle of power to whatever is plugged into it. For example if I plug my phone into it to charge and the laptop is powered on, it charges it normally, but if I disconnect the laptop or shut it down, the hub still charges the phone, but does so extremely slowly. (what would normally be charged in 2 hours might take an entire day to charge). When the laptop is off or disconnected, the power light on the hub remains lit, (as it should, it's plugged into the wall) but the output drops to almost nothing.
Why does this happen? It does the same thing even if there is only one thing plugged into it, or if everything is plugged into it.
Thanks!
Eric
Thanks!
Eric
