[SOLVED] Usb hub suggestions
Parroty69
Great
Oct 27, 2021
217
7
95
I am looking for a usb hub that is cheap and good. I only need it to output usb 3.0 or usb 3.1
Do you have any suggestions for what I should look for in a usb hub?
geofelt
Parroty69
Great
Oct 27, 2021
217
7
95
"Cheap and good" - unlikely pairing.
How many USB devices must the hub support?
My suggestion, in any case, is to purchase an independently powered USB hub.
And do not go "cheap".
2 or more usb devices is good.
What should I look for in a usb hub?
geofelt
Parroty69
Great
Oct 27, 2021
217
7
95
Thank you for your suggestion. I have 2 devices, one requires 5v 500ma and one that requires 5v 120ma.
Should I use a powered or non powered usb hub?
I have found a usb hub. Here is the link to the product: https://www.ventioncable.com/product/4-port-usb-3-0-hub/
Is it any good?
Parroty69
Great
Oct 27, 2021
217
7
95
I have a 10gbps usb c port. Should I use a use a usb hub and connect in this order: usb c 10gbps port>usb c to usb to usb 3.0>usb hub>devices or this order: usb 3.0 Port>usb hub>devices or this order: usb 3.0 port>usb 3.0 to usb c adapter> usb hub> devices
