I'm at a loss folks. I've Google searched for this mishap and, after trying everything posted on the many sites, have had no luck. Here's the situation:
I have an XPC (running XP SP2) with two hard disks. Disk 0 is an 80GB Seagate SATA drive with letters D:, G:, and F: associated. Disk 1 is a 120 GB WD EIDE drive with letters C: and E: associated. I have a Plextor DVD-RW listed as H:, and at any given time I have a USB flash key that takes up I: and J:, a USB card reader that takes up M:, and a Cat-5 WD MyBook that takes up K:.
I recently purchased a USB to IDE device so I could read the contents of my old 2.5" drives (old mp3 players). When I plug this device in, the computer acknowledges a "USB mass storage device" is installed, but doesn't assign a drive letter. When I manage the PC, Device Manager shows the device listed under Disk Drives as a "Fujitsu USB" (which is fine, it is a Fujitsu 2.5" IDE drive). However, the Disk Management doesn't show the drive as attached.
I have tried any combination of the following:
Disconnecting my Cat-5 MyBook
Using regedit to reassign the other USB devices to other drive letters (N:, P
Using regedit to delete all traces of USB devices then plugging in my new USB-IDE device (no avail)
My computer can see the USB device attached. It has correctly identified the device attached as a Fujitsu drive. Why no drive letter?
Thanks
Thanks
