Question USB not working after FORMAT
Apr 17, 2019
Hi! I am a new member on this forum and i need some big help from you. I am a videographer and today my client come to me to copy his movie on HAMA 64gb Usb, Which is compatible with phone [Photo Link] . I have a notebook and i run an windows xp where i try to format the USB to NTFS. From my computer let's to format only for fat32. So i go to Disk Management and format from there to NTFS. After this has finished i try to paste the movie and says. Corupt Disk, inaccesibile. After that i try with cmd-diskpart- there says that the drive has write protection and i try from cmd to delete the write protection, it's says finish but i have write protection. Now the drive says the volume was in raw format and instead of 64gb they have 2tb.. Can you guys help me with this big problem? I also tryed with easeus partition master, but it says that i have write protection. Thank you!
Use this link to remove write protection step by step.
https://www.techadvisor.co.uk/how-to/storage/remove-write-protection-usb-3633096/
Lastly, keep in mind you cannot format FAT32 through Windows if it's greater than 32 gigabytes. You would have to use easeUS or some other 3rd party partition manager to achieve this. Good luck!
Hello. I've tryed all the steps and i can't do anything.. in CMD it say's when i push clean : "
DiskPart has encountered an error: The request could not be performed because of an I/O device error.
See the System Event Log for more information."
