Gents,
I have a small problem with my new build. My case is a NZXT Phantom and my motherboard is Asus P8Z68 - V Pro.
The problem I have is the case has two top panel USB ports. A 2.0 and 3.0. The blue 3.0 port is plugged in and working, but the cable for the USB 2.0 port is a 4 pin connector and there is no spot on my motherboard for a single 4 pin connector to plug in, only a couple 9 pin receivers.
Can I plug in the 4 pin to one of the rows on the 9 pin slot and get it to work that way? The wires on the 4 pin cable are Red-White-Green-Black then a dead spot.
Please help!
Please help!
