USB port not recognized
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: microsoft.public.win2000.setup (More info?)
After a clean win2000 installation the OS would not recognize the USB
port (under device manager the USB icon would not appear) and
therefore none of the USB mass storage devices I have can be used.
These same devices have been used in other win2000 flawlessly and used
to work in the same USB port under win98.
I updated everything (Windows 2000 5.00.2195 SP4). This ought to
solve all the problems with the USB port, but still the USB port
remains to be useful.
IS there a way to manually install the drivers that will enable my USB
port.
TIA
_______
computer: old HP Omnibook 4150
Your system bios may need an upgrade.
Regards,
Dave Patrick ....Please no email replies - reply in newsgroup.
Microsoft Certified Professional
Microsoft MVP [Windows]
http://www.microsoft.com/protect
| port.
| TIA
| _______
I would guess that this happened when you upgraded your bios. I have had this
happen after bios upgrades. the solution I have found is to go into the bios
and "load optimal defaults." Probably hitting "F9" and then saving changes.
It's F9 on ntel Motherboards, my be something else on others. I have also
found PS2 ports and IDE hard drives to become unrecognized after BIOS
upgrades. Loading optimal defaults has been the cure all for all these BIOS
upgrade problems.
> Regards,
> | port.
> | TIA
> | _______
