Usb port problems
kats4dog1
4
Hello,
This morning my wireless mouse usb hub worked perfectly in my laptop, this aftenoon, this same mouse usb no longer fits into the usb ports on my laptop. Need help
if it wont physically fit in then check the plastic insert part of the usb connection is still there--on the laptop and the mouse hub
these have been known to come off and leave the bare pins
then if you push a usb device in and the pins touch it shorts out--which isnt good
would you know if this is an expensive fix?
if its on the actual laptop then its probably expensive as its usually soldered to the motherboard
though when its happened to me in the past i have still been able to use any other usb ports as long as i made sure none of
the exposed pins were touching each other in the faulty port
took out the battery--disconnected the charger and used a wooden toothpick to seperate the pins--then taped over the faulty
port so i wouldnt accidently plug a usb device in there
you can add usb ports with a pcmcia card if its the only port you have--or express port card if the laptop doesnt have pcmcia
these would be much cheaper than trying to do anything to the usb ports on the motherboard and just slot in
hope that helps
