Question Usb ports have power but keyboard won’t work
Apr 19, 2022
8
I just built a new Gaming PC and my usb ports have power but won’t run a keyboard to do bios update and install windows, Im lost and i took the whole computer apart and put it all together again, but the problem is still there, any suggestions or answer anything will help i can show pictures and the parts for the computer if needed
https://pcpartpicker.com/list/znKVcb
so there bios screen just keyboard not working? did you try the usb port like I ask the first time?
i’ve tried every usb port with usb keyboards and then the other type of keyboard that is a circular plug and still doesn’t work, yes the bios screen is up i just need a keyboard to work so i can press DEL or F2 to get in to it
without anything to boot to, it suppose to boot to bios. what does it boot to?
i can’t boot up anything cause i need the keyboard to press del or f2 so it will boot up bois, moral of the story my keyboard works for a split second and then it won’t work, the usb ports have power it seems like it’s not enough power to use a keyboard
