Question Usb ports problems
Dec 12, 2021
8
Hi everybody; my usb ports not working in Windows 7. What can I do to enable them?
Lutfij
You won't get much help if you're going to be vague with information. Make and model of your motherboard? Have you tried reinstalling your chipset/USB drivers? Ideally you should parse the specs to your build.
Jul 6, 2022
8
Try another USB port, can the device communicate? If it can, you may have a faulty USB port. Try another device in it. If that also fails, a USB loopback plug can confirm whether it is faulty.
If no USB ports work, enter BIOS and check their interface status, perhaps it has been disabled as a security measure.
Thirdly, uninstall and reinstall your USB drivers.
It's also worth checking your front panel connectors are seated properly.
