usb problem? or computer problem?
Sym David
Commendable
Mar 26, 2016
i have a usb that im using right now to copy files from my computer, but something strange happens, when done copying... all files are there but after ejecting usb.. then plug it again.. all files are gone.. but storage is used when i check properties of the drive.. dont tell me to do attrib -r -a -s -h etc.. or folder option then uncheck hide protected operating system or show hidden files cause it doesnt work.. any ideas?
Hi,
Please do try these troubleshooting steps that may help. :)
- Do test the USB first onto a different PC and see if you'll be able to see those files or not.
- Another troubleshooting step is to format the USB itself then see if the same problem will persist or not.
- If other USB driver works just fine that means it's the USB drive that is faulty.
