USB problem with old GA-5AA
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
Hi,
Running Win 2000 SP4 on rev 2.2 of this MOBO...
I have a Belkin F5U005 USB card and when I try to connect my ADSL modem it
will not work...
I've got all the latest BIOS and MOBO upgrades from Gigabyte, and the latest
drivers for the modem and I've tried the USB card in all the PCI slots...
To make matters worse, other USB devices (printer, SM card reader) all work
fine...
Any ideas?
TIA
Susan
"Tiscali" <kegler@tiscali.co.uk> wrote in message
news:41defa2b_4@mk-nntp-2.news.uk.tiscali.com
> Hi,
> will not work...
> latest drivers for the modem and I've tried the USB card in all the PCI
> slots...
> work fine...
> Any ideas?
> TIA
installed correctly?
http://search.belkin.com/cgi-bin/MsmGo.exe?grab_id=161&EXTRA_ARG=&CFGNAME=MssFind%2Ecfg&host_id=42&page_id=5570816&query=F5U005%2A&hiword=F5U005%2A+
maybe try the modem on any 5AA port - not the Belkin card
"SteveK" <nospam@iPrimus.com.au> wrote in message
news:41df32bc_1@news.iprimus.com.au...
>> Hi,
>> it
>> will not work...
>> slots...
>> work fine...
>> Any ideas?
>> TIA
Hi,
Thanks for the reply - unfortunately the mobo hasn't got a USB riser
attached to the connector - any idea where I can get one of these that'll
fit?
Susan
news:41e038b1$1_4@mk-nntp-2.news.uk.tiscali.com
>>> Hi,
>>> it
>>> will not work...
>>> slots...
>>> work fine...
>>> Any ideas?
>>> TIA
> Hi,
> fit?
This one will do nicely!
Belkin USB 2-Port Motherboard Cable (F3U001EA)
http://www.savastore.com/productinfo/product.aspx?catalog_name=Savastore&product_id=10278731&pid=45&tid=2
However, there are other shops offering the same for less money.
You will need a 2x 4pin mobo flat connector.
If it's a 2x 5-pin mobo connector dont worry! - just clip off the shield
pin.
Use a fine cutter if needed. Those 5 pin cables just add shield to support
USB 2.0 speeds
