The broken PC saga continues, but is hopefully close to reaching a happy ending. 🙂
Ever since doing the second format of my PC last week some time the front USB ports haven't worked, which wasn't a massive drama (okay, it's still annoying though) until I just bought a Maxtor One Touch III external drive thingy that just doesn't seem to work at all.
I plug it into the front USB ports and obviously it does nothing, when I plug it into the back ports it fails to install but at least Windows recognises it (just has a yellow exclaimation mark and says device failed to start) and the lights on consistantly so I guess it's not a power problem.
So, my USB ports are well and truely screwed. I'd love to sort it, and I'd love to sort the front USB ports too if possible.
I've got an Asus a7n8x-e deluxe motherboard, afaik everything's setup correctly in the BIOS and I think the drivers installed correctly. I tried removing some of the USB devices from the device manager to try and re-install the drivers in case something was corrupt, in turn this just killed my mouse and keyboard and it wouldn't re-install when I rebooted the PC, yes, I'm dumb 🙂
Any help in this matter would be ace, thanks!
