[SOLVED] USB sound adapter won't work anymore ?
rscheetah30
Splendid
Jun 8, 2018
325
9
23,615
For some reason, my usb sound adapter stopped working on Windows 10.
But the strange thing is that on both Windows 7 and Windows 11 it works just fine.
The sound adapter appears on Device Manager with a yellow exclamation mark. I've tried updating its drivers but Windows won't let it install. I've even tried restoring an old Windows 10 image but the problem still remains. I've tried uninstalling and reinstalling the drivers for it without success. I've tried checking the ssd for errors and SFC to no avail.
What could be causing this?
PC Specs
MB: Asus M5A78L-M LX V2
CPU: AMD FX-6300
GPU: Radeon R7 240 2GB
RAM: 16GB DDR3
3 x HDD + 1 x SSD
PSU: Gamemax GP 650
You forgot to list the usb sound adapter within your system specs.
There may be some useful usb setting options within your BIOS/UEFI which may help accommodate adapters.
Windows updated yesterday ?
If so uninstall the recent update from control panel, programs and features
Make sure the device reboots after uninstall
Try that and you can reupdate windows again that if it is not the problem
No, I paused updates on Windows 10 a long time ago. But I'll take a look at it to make sure.
