USB Sound Card doesn't remove buzzing (?)
External soundcards don't catch static from the components in the pc(fans beeing the worst), but they are styll very much dependent on the quality of the current they get through USB, especially in such a small unregulated design. You may have better luck wiht a larger, higher quality one, and you may have more luck with a better PSU, I don't know, honestly. Bui i can tell you for sure that you are never getting quality from such a diminutive design.
Tried other usb ports, same result. How do you power it externally and I don't know anything that has to do with motherboard current. I'm lacking knowledge in that part.
Oh. sweex 7.1 external usb sound card (other one i don't know sorry (https://gyazo.com/cc09bdeda9bc75ec4829bec665cd2288 ) ) and psu is THERMALTAKE Berlin 630W 80Plus
Ah, hell i forgot to insert the link. SO it's one like in teh picture? You said 7.1 and i thought you were talknig about this: http://www.sweex.com/en/notebook-pc-accessoires/geluidskaarten/SC016/
Well, if it's as small as in the picture, i wouldn't expect much sound quality from it and would expect better from the audio on the motherboard..
I heard that the usb sound cards doesn't conflict with all the electricity going through all parts and that it removes the annoying static noises and all usb sound cards should do the same job. I bought it with the hope that it will fix that annoying sound that is always bothering me. There's a comparison video aswell with even cheaper usb sound card https://www.youtube.com/watch?v=R4PGZCvUyKI
