J John_495 Commendable Oct 4, 2016 2 0 1,510 Oct 4, 2016 #1 Hi my pc and my lamp share one power source, when i plug the lamp i hear the usb sound! also with other devices. Is that a problem? Is it correct that my pc share one electric shocket strip with other home devices? thanks!
Solution N N nigelivey Oct 5, 2016 Check to see if your wall socket has an earth pin or hole (depending on location) and that it has an earthwire attached to it in the wall
N nigelivey Splendid Dec 6, 2011 2,648 50 29,540 Oct 4, 2016 #2 Sounds like an "earthing" or "grounding" issue. Upvote 0 Downvote
J John_495 Commendable Oct 4, 2016 2 0 1,510 Oct 5, 2016 #3 so? is that bad? I nedd to do something? Upvote 0 Downvote
N nigelivey Splendid Dec 6, 2011 2,648 50 29,540 Oct 5, 2016 Solution #4 Check to see if your wall socket has an earth pin or hole (depending on location) and that it has an earthwire attached to it in the wall Upvote 0 Downvote Solution
