Question USB stick Asus Wireless, what I can do with it?
danny009
575
57
10,970
I own a usb stick wireless from asus, what I can do with it? I plugged it in a usb port and my ethernet icon sys tray turned into wifi icon and there is new icon at network panel on Windows 10.
Modem in the living room and my laptop is in my room, long corridor distance so wifi doesn't work, however can I increase the quality of the wifi from modem somehow by using this stick?
Thanks
It is not some magic device that can create wifi signals that do not exist.
It purely is a wifi nic you can connect via a USB port. It works no different than the internal card in most laptops. Many times the internal cards work better because the antenna are larger.
I guess you could take a long USB cable and run it down the corridor so it is closer to the router than your pc is.
Reactions: Dark Lord of Tech
