G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I have an IBM Thinkpad running XP 5.10.2600 SP1.
I have just got a new cellular phone (Nokia 6610i) with a serial-to-USB
cable to manage the phone from the PC. It works fine when using the Nokia
PCsuite, which handshakes with the phone thru the port
Device class: Ports
Device description: Nokia CA-42 USB (COM2)
Driver provider: Nokia
Driver date: 1-10-2005
Driver version: 5.2.14.3
Device status: Enabled
No resources used
(it was originally on COM7, but I changed it after reading a thread in this
newsgroup).
The problem is when I try to use the phone as a modem: Nokia tells me that I
have to install the modem driver over the cable, but XP does not allow me to
select the correct port; it just lists COM1 (which btw is on Intel(R)
82801DBM LPC Interface Controller - 24CC ).
Any clue how to fix the issue?
Thanks in advance
Mario
Device class: Ports
No resources used
newsgroup).
Thanks in advance
Mario
