USB to USB cable is not working...!!!
goku123456789
36
I have usb to usb cable i want transfer data from the laptop to the PC....but the problem is when i connect the both of the ends to the usb ports nothing happens....any help would be appreciable!!! Please reply guys i really need help.
A standard USB-USB cable will not work. In fact, you may short something out.
See this:
http://www.hardwaresecrets.com/article/Connecting-Two-PCs-Using-a-USB-USB-Cable/248/1
And this from an earlier Toms discussion:
http://www.tomshardware.com/forum/257340-45-cable-tranfer-files
Connecting any two computers using USB requires a special proprietary bridge cable; the usual USB-to-USB cable does not work as USB does not support such type of communication and attempting to do so may even damage the connecting computers as it can short the two computers' power supplies together, possibly destroying one or both machines or causing a fire hazard.[3] Therefore, Direct Cable Connection over USB is not possible; a USB link cable must be used, as seen in the Microsoft knowledge base article 814982. However, with a USB link cable, a program which supports data transfer using that cable must be used. Typically, such a program is supplied with the USB link cable. The DCC wizard or Windows Explorer cannot be used to transfer files over a USB link cable.
