Usb type C port with usb 3.1 mobo header
AJStyles
14
I am buying a Asus prime h270 plus motherboard and SilverStone RL-05 cpu case
My question is can I connect the usb type C port with mobo's usb 3.1 header?
Also if you conect usb 3.0 port to mobo's 3.1 will it give the performance of usb 3.1? If not any suggestions for a cheap case with usb 3.1 ports on front?
you can keep your current case, simply buy a usb 3.1 front panel
it would require you to run a cable from the back to the front panel
so you would need a front panel hub
and a 3.1 cable long enough to run thru...
Some cases come with handy holes pre installed, if you are lucky... if not you would need to modify the case
Thank you very much.One last thing.Will this be compatible to asus prime h270 pro and SilverStone RL-05 case and is it necessary to connect type-c port of case to type-c port of mobo.Can't I connect it to usb 3.1 header of mobo?
your case has no holes in the back to run the cable thru, so not without modification no
much easier for you
https://www.asus.com/Motherboard-Accessory/USB-31-UPD-PANEL/
Is it necessary to connect type-c port of case to type-c port of mobo.Can't I connect it to usb 3.1 header of mobo?
Case already has a C-type port.The only problem left is front panel that has usb 3.1 gen 2 and is not expensive like https://www.asus.com/Motherboard-Accessory/USB-31-FRONT-PANEL/
No as there are only a few cases right now that can utilize USB 3.1 Gen 2 headers.
Your case only support USB 3.1 Gen 1 which is still USB 3.0 but just renamed to this. Your type C port is usb 3.1 gen 1 so it uses the same USB 3.0 (usb 3.1 gen 1) header. It does not support the new USB 3.1 Gen 2 header. Your motherboard already support two USB 3.0 headers.
You need to understand that USB type C does not indicate the speed/bandwidth, it only tells you the the type of connector used.
