Hello! I'm wondering if buying a USB antenna would be worth it for me or not.
I'm currently in tech school for the AF and the internet situation is not exactly ideal.
According to my laptop I get decent signal, 4-5 bars, but I'm wondering if an even stronger signal would help. The laptop I'm using is this; https://www.asus.com/us/ROG-Republic-Of-Gamers/ROG-G751JT/specifications/
The onboard NIC; Integrated 802.11a/b/g/n/ac
Built-in Bluetooth™ V4.0
10/100/1000/Gigabits Base T
If I were to buy something like this, would it be an upgrade in signal strength? The internet we have is only supposed to be 30mbs down, but I usually get around 15 using my onboard wifi. So I'm not too worried about maximum speed of the USB antenna as long as I can reach out and grab the full amount I'm supposed to get, if that's how it works.
I'm interested in the following...
http://www.ebay.com/itm/Dual-Band-High-Gain-Antenna-802-11ac-1200Mbps-USB3-0-AC1200-USB-wifi-Adapter-/331951288635?hash=item4d49d6b13b:g:4yEAAOSw65FXv9FM
http://www.ebay.com/itm/EEEKit-High-Power-2-Antenna-6dBi-USB-Wireless-WI-FI-Adapter-150Mbps-802-11-b-g-n-/182243955959?hash=item2a6e9614f7:g:EX0AAOSwENxXmbe-
(another usb antenna, smaller)
Are these worth the money? How do the above compare to what's already in my laptop, will there be a noticeable increase in performance or at least range?
Thank you
Thank you
