So, I have a tablet that I'm using as an additional screen, but it does not seem to be able to pull sufficient current from the USB 3 port it is plugged into to remain on. Could be the tab, it's kind of bad and its battery has certainly seen better days, but I'm hoping to make use of it as it's far easier to mount than a regular screen in that position.
Anyhow, my idea as a solution to this problem was a cable such as this one:
here
I can't find the MM-F version I found the other day, but I'm mostly concerned about the principle and this is basically the same idea.
Now, on to my question - is it possible (and not dangerous to the mobo) for me to feed the subsidiary with wall-charger power (probably a 2A charger) and then keep the data plugged in? I'm thinking I would probably cut the ground/volt line on the main-usb, to avoid any issues with feedthrough? Is this necessary?
here
