use android phone as bluetooth/wireless speaker
Rahul Shaw
my laptop speakers are gone.. so i am trying to connect my phone to the computer such that i can use my android phone's speaker. any help will be appreciated.
Gagan is there not an other way through bluetooth,cuz my lappy does not recognize the Realtek audio drivers. Sounds in control panel only shows bluetooth hands free audio so i asked a way through bluetooth.
It is likely that such an App doesn't exist. What you searchfor is an App that transforms your Smartphone (or Tablet) into an A2DP sink (that receives the Audio from a A2DP source).If you're interested in building such an app or you might want to know why there isn't yet such an app. There are several technical difficulties to build such an application but the most difficult one might be that android doesn't support the A2DPmode by simply not letting you configure its A2DP to be a sink.Considering that probably much more experienced users/developers (no offense!) gave up this approach, it might be easier for you to get your WiFiworking properly. There are several possibilities to fix a weak WiFi signal (adjust the antenna of AP and Client, removing obsticals etc.).
