Ok, i apologize if this question has been asked before, but it seems the answers are 50% yes and no. I have a Sapphire Nitro RX580 8gb, it has an 8 and 6 pin power connection. My PSU is a Seasonic Focus Gold 550w semi-modular. It came with 1 pci-e cable for GPU, which is 8 pin on one end and has 2 6+2 connectors on the other end. If needed, my motherboard is MSI B450 Gaming Pro Carbon AC.
Do i need to use the 6 pin in addition to the 8 pin connection on the GPU, and if so, will that 1 cable work or do i need to purchase a separate cable? Currently the card works, but will there be increased performance with more power? And i do plan on overclocking at some point.
Thank you in advance for your help.
