Use of network X cable between two NIC
Vlad
40
Archived from groups: microsoft.public.windowsxp.customize (More info?)
In the pass the use of network X cable between NICs was mandatory
when networking between two or more computers.
Today, can I use an ordinary cable or is that optional ?
Vlad
"Vlad" <Bla@dot.com> wrote in message
news:11pbr012shupdqdadq5khj56dkupivki9f@4ax.com...
> Vlad
The use of a crossover (X) cable is necessary if you are *directly*
connecting two computers via NICs. A regular cable will not work.
If there is a hub or switch in the path, as there most often is these days
(often as part of a router), the crossover cable is not appropriate and
won't work.
Note that if you are just using the crossover cable, you almost certainly
also have to set fixed IP addresses to both cards. This is also not
necessary if there is a router in use, which almost always has DHCP services
supplying IP addresses.
HTH
-pk
>> Vlad
>won't work.
>HTH
>-pk
Excellent information
Thanks
Vlad
