Use PCS for internect connection via laptop???
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: alt.cellular.sprintpcs (More info?)
Wondering if possible to use PCS as telehone line connection to laptop
modem? Rather than pay for seperate expensive SPRINT internet
service, would like to use available PCS minutes so that my laptop
would dial out via the cell phone. Is this possible?
Thanks
"Herve L. Guerette" <xguerette@cox.net> wrote in message
news:4c5t70tqgsf75nntji9pag1hsjl7uc8emf@4ax.com...
> Thanks
Yes and No. Depending on how old your phone is, if it's a 2G phone, you can
add Wireless web to your account, pay an additional monthly fee and use
minutes. You will only get 14k in speed though.
If you have a 3G phone, nope. That uses Vision, and you will need to have
the Vision option on your account. It doesn't use any minutes, but, in
saying that, SPCS does not support connecting the phone to a laptop. Vision
was not designed to replace your regular ISP service and if you connect
online for a long time or do large downloads, you will be charged extra, and
may have the Vision option removed from your account.
Some of us, while on the road, will connect via our laptop, but just to
handle email and limited surfing on the web.
Bob
Thanks Bob - big help. I searched SPRINT site and did not see
reference to 2G phones - how would I recognize and how would I connect
such a phone to laptop?
I'll also try stopping at SPRINT store to see if have phones and get
additional information on connecting.
Have vacation home - no need for land line but would like to have
internet/email access. Hoping PCS will do the trick.
Thanks again.
On Thu, 15 Apr 2004 14:16:06 GMT, "Bob Smith"
>> Thanks
>Bob
news:thgt70hvlr250ga9td6m1oa9vjg4bkgm83@4ax.com...
SPCS probably doesn't have any 2G phones available. Most recent phone they
had was the Sanyo 4700.
Unless they have an older reconditioned phone to swap out behind the counter
or in the back room, I don't think they will have any either.
Best best is to search eBay. Lots of 2G phones for sale. You can't go wrong
with the Sanyo 4700, if you can find one. You will also need to find a cable
the model you finally select to connect to the laptop. You will also need to
contact SPCS to get WW added to your account.
A couple of more things to ask. Do you currently have service through SPCS?
If so, have you checked to see whether you have coverage by your vacation
home? Which phone model do you currently have?
> Thanks again.
Anytime.
Bob
Once again, I thank you for your help.
Doing a bit of research and looks promissing. My wife and I use
Samsung A460 and 8500 phones. Looking at the manuals, both discuss
using phones to connect laptop to web. Just what I'm looking to do.
Are the phones we have 2G compliant or do we still need something like
the Sanyo 4700?
I'll now need to research costs of adding Sprint web access and where
to buy cable and any sofware we might need to work with our laptop.
Both our permanent and new vacation homes do have Sprint coverage.
Any thoughts or suggestions on helping to move this along would be
most appreciated.
Hervé
On Thu, 15 Apr 2004 17:34:24 GMT, "Bob Smith"
>> Thanks again.
>Anytime.
>Bob
Your Samsung 8500 is a 2G phone that will work very well with
Wireless Web. I used one that way for several years. Check out:
http://navasgrp.home.att.net/tech/sch-8500/
You don't need any software, just a cable.
John Richards
"Herve L. Guerette" <xguerette@cox.net> wrote in message news:4j8u70hhvpfd74vl12gh8pmgs0e20u8vhg@4ax.com...
> the Sanyo 4700?
> most appreciated.
> Hervé
Ok ... What plan are you on now, how many minutes, do you have N & W, and do
you even possibly have WW as an option your account as well?
> the Sanyo 4700?
As John mentioned, the 8500 is a 2G phone, not sure whether the A460 is. So
to answer your question, no .. you won't need to get a 4700.
The Wireless web option, if I recall correctly, is $10/mo. Might even be
$5/mo. The tough thing to find will be the cable, as the 8500 has been
discontinued for awhile. You can check with Radio Shack, eBay, or just do a
google search for the cable.
No need for any software, per the instruction John Navas has on his web page
(the link that John Richards provided)
That's good to hear.
> most appreciated.
Yes, as mentioned, WW is slow ... 14k speed, so if you are using most of
your plan minutes talking, then you might go over your bucket of minutes
accessing the web. If you have plenty of minutes left on your plan at the
end of the month, it shouldn't be a problem.
Good luck in finding a cable.
Bob
Thanks for information. Just visited local SPRINT store and want to
share what they had to say.
My Sansung A460 is a 3G talk but only 2G data. Said could connect but
would be slow and result in extra charges.
Suggested that I purchase a 3G phone like the Samsung A620/VGA1000.
While costs $260, I'm entitled to a $150 credit in June when I'll have
had present phone for 18 months. So, I could upgrade for about $110.
Then, I could buy data cable and software from Radio Shack or
elsewhere. Since my plan provides for unlimited Vision (2000 anytime
minutes/mo which I share with my wife's phone = $80/mo), said I'm
entitled to unlimited web connection at no additional costs. And,
service is faster than dial-up!!!
Sounds fantastic. Let me know if sounds right to you. Othersise, June
1st I'll swap phones with my wife, upgrade mine to the VGA1000 and
solve my problem.
What do you think???
On Fri, 16 Apr 2004 12:10:50 GMT, "Bob Smith"
>> the Sanyo 4700?
>> most appreciated.
>Bob
In article <cob0801tbppr9ldjvf4ao2iph965pf0oaq@4ax.com>,
Herve L. Guerette <xguerette@cox.net> wrote:
> I'm
On paper it may be, but Network overhead or whatever makes Vision
painfully slow.
"Herve L. Guerette" <xguerette@cox.net> wrote in message news:cob0801tbppr9ldjvf4ao2iph965pf0oaq@4ax.com...
Don't know about the A460 (since it's a hybrid), but your Samsung 8500
will not incur extra charges except for the flat $5 per month for the WW option.
> elsewhere.
The cable is $20 at Radio Shack, but can be found elsewhere for $9.
No software required, except for the free USB driver.
Unlimited Vision is only for using it on the phone. Tethering it to
your laptop does not entitle you to unlimited web connections.
Some people have reported a 50 MB tethered download limit per month.
John Richards
Herve L. Guerette <xguerette@cox.net> wrote in message news:<cob0801tbppr9ldjvf4ao2iph965pf0oaq@4ax.com>...
> solve my problem.
It's against the Terms of Service:
http://www.sprintpcs.com/common/popups/popLegalTermsPrivacy.html
(Under Terms and conditions of Service, scroll down to "Other Terms
Applicable to PCS Vision Usage")
> Unlimited PCS Vision plans/options are only available with phones or PCS
> smart phones where the device is not being used as a modem in connection with
> other equipment (e.g., computers, PDAs, etc.) through use of connection kits
> or other phone-to-computer/PDA accessories, or Bluetooth or other wireless
> technology. Sprint reserves the right to deny or to terminate service without
> notice for any misuse.
Well ... Yes & No. Yes, you would have an extra monthly charge by adding the
WW option to your account. It's either $5 or $10. Any usage on line, either
by just the phone or while tethered to the laptop, minutes would be used off
your plan. No extra charges ... In saying that, it is slow. As slow as a fax
machine.
Yes, you could. By that time, a few more SPCS phone models will be
available, and will have the same $150 credit.
As John said already, unlimited only applies on Vision, while accessing
Vision on your phone, not while it's tethered to the laptop. It is a quicker
speed than WW, and doesn't use minutes. As mentioned by yours truly and
others previously, in this thread and other threads, one can use the phone
tethered to the laptop, and do just casual usage. If you do a lot of
surfing, or do large downloads, SPCS will notice, give you one warning about
it, and then possibly cancelling the Vision option on your account, and
start charging you $0.01 per kb down or uploaded through the service.
> solve my problem.
Again, you might look at other models before you buy. The number one rated
line of phones in this newsgroup are by Sanyo. Nary a complaint on any of
their models.
Bob
And some of use run a webcam mounted on the dash!
If you change one or both of your phones to a Vision phone, you
would likely want to add a Vision Pack to your plan. Which would make
your #80 plan a $95 plan. Otherwise you would be charged $.01 per KB.
> solve my problem.
>>>the Sanyo 4700?
>>>most appreciated.
>>Bob
> painfully slow.
As I said before, if the RL(whatecer you are using) is based on the
Sanyo 4900, then it WILL be slow. Its the browser. Visino on my Sanyo
8100 is great.
In article <aAmgc.11070$jT5.8981@newssvr23.news.prodigy.com>,
JRW <no_addy@no_.com> wrote:
> > painfully slow.
> 8100 is great.
I dropped Vision long before my 2 month trial was up, it was S L O W
on the RL2500.
xguerette@cox.net says...
> solve my problem.
What store told you this?
In six months, you're going to be calling us to cancel because that
Vision service got removed and now you're paying a penny per KB.
Doesn't sound bad until you think that an 80 MB game update would
cost you $800.
With the two phone you have right now, using SPCS as your ISP, so to
speak, you get max speeds, under ideal conditions, of 14.4kbps, and
pay $0.39/min while connected, unless you opt to include the Wireless
Web service pack on your phone(s). And if you add that pack, then
your web usage gets treated as a voice call, and so counts off as
voice minutes just like a regular call would do.
If you're talking about using the phones as a real modem, to dial
AOL, for example, then it's $0.39/min no matter what you do, and
still max out 14.4kbps. That's true of either 2G/Wireless Web
phones, or 3G/Vision phones.
Vision phones are capable of higher connection speeds, and far more
folks have reported pretty decent speeds than otherwise. However,
this kind of use of a Vision phone isn't supported. To use it that
way, with SPCS as your provider, will (if you get caught) get your
unlimited Vision pack removed, and then you pay that penny per KB I
mentioned above. For the wording that applies, look for "Terms &
Conditions" at the bottom of http://www.sprintpcs.com and then search
the page that pops up for "connection kit".
So far, the only customers I've seen enforced under this policy have
been obvious examples. One of them over 10GB in a month. Rumors
abound about where the limit is that gets attention. I'd do you a
disservice to add to those rumors, because that's all I have myself.
Just be aware of the consequences if you move to that Vision phone
and do it.
RØß
O/Siris
I work for Sprint PCS
I *don't* speak for them
In article <178e0a7170b01c0c27ff831c6e9a2832@news.teranews.com>,
Another secret SprintPCS policy.
"Robert M." <rmarkoff@msn.com> wrote in message news:<rmarkoff-F58461.05380821042004@news02.east.earthlink.net>...
How can it be a secret if it in clear Elglish in the ToS?
In article <7e761144.0404210554.67f71e0e@posting.google.com>,
Its secret cause you just said so. "Rumors"
The policy is not a secret, its sometimes enforcement is.
"Robert M." <rmarkoff@msn.com> wrote in message news:<rmarkoff-9F90F1.09472821042004@news05.east.earthlink.net>...
So then you expect a company to put a policy out then not enforce it?
That makes no sense whatsoever. They put the policy in the ToS and it
is expected ot be enforced.
The KB limits are not what's stated, because it states ALL USAGE of
3rd party equipment and using it to connect a laptop / PDA is a
violation of the ToS, so according to that you hook it to a laptop and
download 1KB, you're in violation.
Also, learn how to read who posted what, I didn't say it was a rummor,
O/Sirus did.
"TechGeek" <pcsguy@bellsouth.net> wrote in message news:7e761144.0404210554.67f71e0e@posting.google.com...
The secret is the limit in MB/GB that it takes for SprintPCS to actually
enforce its ToS policy.
We all know that SprintPCS tacitly permits low volume data use on
voice plans, contrary to the stated ToS.
John Richards
John Richards wrote:
> <snip>
And for that, we thank them!
Larry
In article <7e761144.0404211103.4b5b66c9@posting.google.com>,
No, but that is EXACTLY what SprintPCS is doing.
In article <SYyhc.162$lY6.0@newssvr16.news.prodigy.com>,
Thank you for more clearly stating what I was driving at.
