I know that USB 3.0 uses different pins that the USB 2.0, and that I can use USB 2.0 into a USB 3.0 port, because it has both.
The problem is that my USB 2.0 port, which is next to the USB 3.0 into the same port is DEAD, I could use USB 2.0 and USB 3.0 devices into the same port, but now I just can use the USB 3.0 port alone.
I want to know if I can use the 5 pin USB 3.0, and use 4 of them to plug a USB 2.0, because there is no USB 3.0 mouse, please don't answer: the port can use both, 2.0 and 3.0.
Thanks
Thanks
