Hello
I recently got a GTX 1060 and would like to upgrade my old AMD(phenom 1055t) cpu.
The heavy use of my PC is mostly for gaming. I play all sorts of games but I'm not an upgrdae junkie. Would be nice to use the abilities of my new card though.
At first I thought I'll get an FX-8350 to go with my board but after some research I realized that for the same price I can get a much better used haswell CPU. (for the same price of a used i5-4670 I can get a NEW fx-8350)
I have a deal for good boards H87/Z87 for around 80$. And then I can still use my old board+cpu.
My questions are:
*How much is the Haswell (4670 / 4670k) better then an overclocked fx-8350. Is it worth the trouble?
*About the Intel cpu. I can get for around the same price (~20usd difference) either one - i5 - 4670 / 4670k / 4690
If they were new I'd go with with the k version, obviously. But since it's a used CPU I need advice. Do you think it's wise to get a used cpu for overclock use. I'm guessing the k version was overclocked, as that's the reason to buy it. And the Haswell work on such high temps. How is it's life span..?
Thanks for the help
My questions are:
Thanks for the help
