I recently got a used Palit Gamerock RTX 3080 10 gb from a local store. Run the usual tests and everything looked fine temps and performance no artifacts as well in any of the tests I ran. Anyway once I installed the th GPU in my system the GPU would crash after 1.5 or 2 hours of gaming or heavy load, with fans occassionally ramping up all the way to 3500+ RPM, and also when it crashed. I used to watch temperature using MSI Afterburner, but suspected maybe more is to it. Downloaded HWInfo and saw that GPU hotspot surpasses 105°c when the fans ramp, which leads to core clock decrease to base clock and sometimes crashes the GPU. Tried decreasing the GPU power limit to 50% which stopped the crashing even after 5+ hours of heavy load, fans stopped ramping and hot spot temperature maxed at 87°c.
So what could be causing this? Would a repaste be enough to solve this problem? Or could it be a faulty GPU and I should be trying to get ky money back? All help is appreciated
System Specs:
MB: Gigabyte b650 Gaming AX
CPU: AMD Ryzen 5 7600x
Mem: 1x16gb DDR5 5200mt/s
GPU: RTX 3080 10gb Palit Gamerock
PS: Ximatec 750w 80 plus silver
System Specs:
